It is currently Tue Aug 12, 2025 5:43 am
 Post subject: Removing Top
PostPosted: Tue Jan 26, 2016 3:58 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
What is the sequence for removing a top? Router the bindings off with binding jig, and then the same for removing the top from the linings? I'm not worried about trying to salvage any part of the top.
Top was braced and glued to the rims at about 47%RH, and all was fine, until I lightly dampened the top to raise the grain before WB finish. It's now pretty much flat, and looking to stay that way.
The only real heartbreaking part is losing the spalted maple rosette. It was a perfect match with the headstock and tail wedge. Thanks for any direction you can give me to learn a new skill!
Alex
 Post subject: Re: Removing Top
PostPosted: Tue Jan 26, 2016 4:08 pm
Last Name: Kincheloe
Who says you have to lose it? A good way to rescue rosettes from scrapped tops is to route or chisel through from the back side until you reach the rosette wood.
Strange that it would flatten after being fed water. Usually after drying out, they get stuck in their concave state. But I guess that doesn't go both ways, or else it would have gotten stuck in an overly convex state.
These users thanked the author DennisK for the post: Alex Kleon (Wed Jan 27, 2016 8:38 am)
PostPosted: Tue Jan 26, 2016 4:52 pm
First name: Alex
Last Name: Kleon
City: Whitby
The guitar was pretty much ready for finishing, so there won't be much thickness left to the rosette and purf lines after thinning and sanding, Dennis.
It was pretty fragile spalt to begin with, and it was glued to a 1/64" piece of ply on the back side.
I still have enough to do another rosette, but the ink lines won't be quite as nice.
Alex
PostPosted: Tue Jan 26, 2016 5:01 pm
If it didn't go concave I would glue a bridge on it and string it up in the white. Flat can be O.K.- many guitars have been built that way. The strings might pull some arch back into the top.
These users thanked the author Clay S. for the post: Alex Kleon (Wed Jan 27, 2016 8:38 am)
PostPosted: Tue Jan 26, 2016 5:18 pm
I would want to stop and think about what's going on. What is your shop at right now? To have it go concave after wetting the outside surface is opposite of what you'd expect.
These users thanked the author meddlingfool for the post: Alex Kleon (Wed Jan 27, 2016 8:38 am)
PostPosted: Tue Jan 26, 2016 5:36 pm
First name: Alex
Last Name: Kleon
City: Whitby
Just came from the shop, and it is 48% RH. I'm confused as to how it went concave, as well.
Alex
PostPosted: Tue Jan 26, 2016 6:52 pm
Have you checked you hygrometer with a wet bulb test?
These users thanked the author Jim Watts for the post: Alex Kleon (Wed Jan 27, 2016 8:37 am)
PostPosted: Tue Jan 26, 2016 7:03 pm
First name: Tom
Last Name: West
State: Nova Scotia
Alex: I would be questioning the accuracy of the RH gauge. Also did you check the arch after gluing or just a quick look. And as Clay says "if it's not concave string it up".
Tom
These users thanked the author Tom West for the post: Alex Kleon (Wed Jan 27, 2016 8:37 am)
PostPosted: Tue Jan 26, 2016 7:06 pm
First name: Tom
Last Name: West
State: Nova Scotia
This may be of interest if you decide to remove top.
http://www.grevenguitars.com/retopping-demo.html
Tom
PostPosted: Tue Jan 26, 2016 7:27 pm
First name: Alex
Last Name: Kleon
City: Whitby
Tom
The arch was fine after gluing the braces, after the top was glued to the sides, and up until I dampened the top. Maybe I over carved the braces? They are still tight, with no separation.
Thanks for the Greven link, Tom!
Alex
PostPosted: Wed Jan 27, 2016 9:16 am
First name: Alex
Last Name: Kleon
City: Whitby
Using the salt test after 12 hours, it looks like my hygrometer is pretty accurate.
Alex
PostPosted: Wed Jan 27, 2016 1:21 pm
I've salvaged rosettes in the past. It's kind of tricky to get it spot on but a good skill to practice. And since you are otherwise trashing it, you've got nothing to lose.
Try this:
carefully measure the actual diameter of the soundhole. Then make a "plug" that exact same size. This is pretty easy by drilling a 1/4" hole and using a circle jig with a trim router. (not sure what your rosette setup is). Then fit the plug into the soundhole of the old top. It might take a touch of shimming with binding tape to get it even and tight. Once it's in, just cut it out of the top with the same router. It will likely end up a touch smaller due to the fact that it's next to impossible to get the plug exactly centered. But I say give it a shot. You can always border it with purfling on the new top.
These users thanked the author Pwoolson for the post: Alex Kleon (Wed Jan 27, 2016 2:07 pm)
PostPosted: Wed Jan 27, 2016 2:17 pm
First name: Alex
Last Name: Kleon
City: Whitby
With the advise give here, and from Steve Denvir, who builds with a true flat top, I am going to finish the guitar, as is, and see how it turns out. I much appreciate the advice given here, as always, and hope to post pictures soon!
Alex
PostPosted: Thu Jan 28, 2016 12:20 am
As long as you have the correct fall away from the top of the soundhole to the neck/body joint you should be fine for the flat top idea. I've only ever built one guitar that wasn't a flat top. Olson, Ryan, Hoffman all build flat top guitars by design. I'm in good company.
So a straight edge along the top shows it flat across the grain? How about along the grain?
Users browsing this forum: Ken Lewis and 19 guests
